brake swap question
Old Sep 28, 2011 | 07:47 PM
m smith's Avatar
brake swap question
Can you swap the disc brakes off a 9-bolt onto a ten bolt with drum brakes directly.Thanks for any replies.
Old Sep 28, 2011 | 08:17 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: brake swap question
Not directly but it can be done.
The brakes are the same but the backing plates are different, and you can't put a 9 bolt disc backing plate directly on a 10 bolt drum axle tube flange.
Old Oct 20, 2011 | 12:50 AM
palric's Avatar
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
is there some parts you can buy to swap from 9 to 10 bolt and keep your PBR setup on the 10 bolt?
Old Oct 20, 2011 | 06:40 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The correct backing plates can be purchased from several sites, to include the following:
http://www.flynbye.com/
The above site also makes a "hassle free" kit:
http://www.flynbye.com/catalog/i30.html
JamesC
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
