Problems with swap from 10 bolt drum to 9bolt disc
Car: 1991 Camaro rs
Engine: 305 TBI
Transmission: WCT5 Rebuilt by Astro
Axle/Gears: Borg Warner posi disc 3.27
My 91RS originally had a 10bolt open rear end, 3.23 gears, drum brakes. I have swapped in a 9bolt posi, 3.27 gears, disc brakes. This is a Borg Warner unit out of a 87 Iroc.
No problem with swap, and car stops great. My problem is with parking brake and adjustment of the disc brakes. From what I can determine, for the unit I have installed, there needs to be an adjustment rod at the "equalizer" to adjust the parking brake cables. There is not an adjustment located there on the 91 model.
I think I need to find an adjustable "equalizer" from an earlier model to help in solving this issue?
Car: 1991 Camaro rs
Engine: 305 TBI
Re: Problems with swap from 10 bolt drum to 9bolt disc
Solved my issue. Removed center console and found spring laying on floorboard. This spring is supposed to be attached to lever which when parking brake is applied rotates a cam, applying tension to the cables and adjusting parking brake. Reinstalled spring.
Parking brake operates as designed, brake pedal is no longer spongy, car stops straight and much shorter than with original drum set-up!
Have no idea how this spring happened to come off, but lead me down many roads before I solved the problem. Hopefully this experience will help some one else down the road.
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
