rear brake not working
Old Nov 3, 2011 | 10:00 PM
lmidden's Avatar
Car: 1987 camaro sc
Engine: lg4 305
i tried to power brake my car and i had the e bake on and had the brake pedal as far as it would go but my tires kept spinning any ideas why this is happening?
Old Nov 21, 2011 | 10:00 AM
mcquigg's Avatar
Car: 85 T/A
Axle/Gears: BW Limited Slip 3.27 w/disc brakes
Re: rear brake not working
are your rear brakes drum or disc?
Old Nov 21, 2011 | 04:09 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Want to know this too. I have drums
Old Nov 21, 2011 | 07:50 PM
skiroulertx447's Avatar
Car: 86 Z28
Axle/Gears: 3.42 posi
If there drums they may not be adjusted right. How high are you revving the engine? The stock pv on these cars doesn't give much braking to the rear. Easy solution to that is an adjustable pv. I had to do this on mine since I went from drums to discs, the difference was night and day(but my rears are actually a little too high right now, locked them up almost hitting a deer).
Old Nov 22, 2011 | 10:01 PM
lmidden's Avatar
Car: 1987 camaro sc
Engine: lg4 305
how do you adjust rear drum brakes and idk whatt the rpm were but it wasnt to much above idle
Old Nov 24, 2011 | 08:30 AM
Sandslot's Avatar
Car: 1987 IROC-Z Z28 Convertible
Engine: LB9
I think you have drum rear brakes? If so, raise the car, secure with a jack. There is an oval slot on the back where a adjuster tool can be inserted. This tool will trun the star wheel at the bottom of the drum brake. Another method is to remove the drum and adjust the star wheel by hand....you can tell if you're too far because you won't be able to get the drum off. One other method that works well IF the brake is in good condition, is to simply apply the brake when backing up. Most drum brakes are designed to do this from the factory - that's why they'll stay adjusted until the get corrosion/debris on them.
Frozer!!!
Jan 19, 2024 04:55 PM
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
AkDrifted
Aug 17, 2015 07:45 PM
kyleb24
Aug 15, 2015 08:24 AM
