drum to disk rear swap
Old Nov 5, 2011 | 10:41 AM
wracksRS's Avatar
Car: 1989 RS,
Engine: 355 sbc
Transmission: t5
Axle/Gears: 3:73
will the factory rear disk stuff bolt up to a drum brake rear? i found a disk rear,but i don't want to swap housings since mine is already geared the way i want it.
Old Nov 5, 2011 | 10:46 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: drum to disk rear swap
No, the flanges on the axle tubes are different. There are solutions available, though.
Old Nov 24, 2011 | 08:41 AM
Sandslot's Avatar
Car: 1987 IROC-Z Z28 Convertible
Engine: LB9
You can swap to rear disc by using an adapter bracket kit on your drum housing. The brake lines and park brake cable ends are different though, so be sure to add a few bucks for those into the project cost
Old Nov 24, 2011 | 03:48 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
don't make the mistake i did and buy a pre 1989 disc brake rear.they are inferior.
Orr89RocZ
Apr 25, 2016 08:28 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
