C5 Conversion Hub
C5 Conversion Hub
Apposed to using the stock rotor turned down into a hub and longer wheel studs is it possible to use C5 hubs on the spindle? Anybody try it? Seems like an easier solution if possible..
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: C5 Conversion Hub
if it was easier, we would be doing it.
you HAVE to use a turned down rotor/hub and longer studs.
besides, 3rd gens have superior hubs (bearings) than the 4th gens and c5's do.
4th gen and c5 hubs bolt to the spindle, they are a non serviceable part, and are in no way compatible with a 3rd gen spindle.
Car: 1987 Trans Am
Engine: LQ9/L92
sorry, no easy way out on this one. grab a set of used ones from the junkyard so you can have the work done without being without the car.
