Rear brakes confusion.
Car: 1986 Pontiac Trans Am
Engine: 355 SBC
Axle/Gears: 2.77
I have a 1986 Trans Am with front and rear disc, the rear are iron calipers. I am planning to buy a fourth gen rear with disc brakes, but I just want to make sure I have all of this straight.
My prop valve will work with the new brakes, because I already have discs?
My master cylinder is sufficient for the new PBR brakes?
I will be able to tie the brake lines on the fourth gen rear into my t block in the rear, because my fittings are all metric?
Thanks for the help, Ben
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Rear brakes confusion.
prop will work, adjustable will be ideal, but it will work
master is fine
brake lines are the same thread, should be fine, but i believe the later 4th gen that have 4 channel abs have 2 rear flex lines?
you will need custom parking brake cables available from flynbye and hawks. Or you have to swap the e brake handle, pull cable and equalizer bar from a later 4th gen as well.
master is fine
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
JamesC
Engine: 355 SBC
Axle/Gears: 2.77
Ok it's becoming clear now. The 1le prop valve is different than just a j65 prop valve?
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Ed Miller has all the parts/knowledge you'll need for any thirdgen brake related problem. His front C5 kit was stupid easy and brake line/ebrake cable stuff makes a fourthgen rear swap practically fall in. He's always swamped as it's a small operation, so you need to be patient. But, IMHO, it's worth it.
Eric-86sc
Apr 3, 2016 03:52 PM
