97 TA rear brakes on Moser 9"
Old Jan 4, 2012 | 06:37 AM
erictheviking's Avatar
Car: '92 RS Camaro
Engine: 406ci D1SC SBC
Transmission: TH400
Axle/Gears: 9" W/Truetrac
As the title, I need brakes for my 92 rear, it has the New style big Ford flanges. A set of rear calipers and discs has come up, and wondered if anyone has used these before, is it a straightforward job. Obviously I will have to make some adapters
Old Jan 4, 2012 | 11:00 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: 97 TA rear brakes on Moser 9"
I have the adapters from Baer for that and they work great. I put their 13" rotors on the rear of mine but did have the stock size on 4 a bit.
I just used the stock 9bolt bracket honed the center out to fit over the bearing and redrilled some holes..
If you look to the bottom left you can see the stock bracket and sitting on the bracket is a shim that puts pressure on the bearing when the retainer plate is tightend down..
Old Jan 5, 2012 | 11:12 PM
TTOP350's Avatar
Wish I had this info back when I did mine..
http://www.moserengineering.com/mose...maroBrakes.pdf
Old Jan 8, 2012 | 08:39 PM
rickyzZ28's Avatar
Car: 1990 RS
Axle/Gears: 3.73 9 bolt
Flynbye makes adapter brackets as well to use 12 and 13" rotors on the back of a 9"
Here is a link: http://flynbye.com/catalog/c16_p1.html
Vintageracer
Jan 10, 2020 05:33 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
red90IROCls1
Aug 25, 2015 06:56 AM
kyleb24
Aug 15, 2015 08:24 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
