disc brake size
disc brake size
i have a 1991 z28 5.7, one of my disc brakes it warped. i was wondering what camaro can i get the front disc brake that is the same size. im just going to grind it down. could i get them off a 91 rs? or 305 tpi? or a 89 iroc?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: disc brake size
don't waste your time with junk yard rotors , go have yours turned for $15 or less and if they are worn down under min spec get new ones there under $40 ea
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: disc brake size
Just an FYI: With the exception of the 1LE front package (11.7" rotors and dual-piston alum PBR calipers), which is rare, all front rotors are 10.5" with single-piston iron Delco-Moraine calipers.JamesC
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: disc brake size
if you buy new rotors save the old ones for a future big brake swap.
Engine: Lb9
Transmission: M20
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
