Ls1 brake question
Old Jan 29, 2012 | 09:12 PM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
Ls1 brake question
Pretty easy question, the bracket that mounts to the spindle, is the bracket holes threaded, or not? Also, is the 2 mounting bolts threaded in from the front, or one from the front and one from the back.
Old Jan 30, 2012 | 05:41 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Ls1 brake question
bolts all go in from one side. the bracket has no threads. the spindle has to be tapped for threads and the abutments for the calipers are threaded
Old Jan 30, 2012 | 06:17 PM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
I figured out my problem which sparked the question, all is fixed now. Thanks for the help.
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
