Confused on rear disc brake swap?????
Old Feb 1, 2012 | 11:53 AM
sick84's Avatar
So I bought a WS6 rear from an 88or89 trans am and want to put it in my 88 camaro. I have been told that it is a direct bolt in but I would have to change the combo valve? why is this? its still a 3 channel line set up like the stock rear.
Old Feb 1, 2012 | 12:07 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Confused on rear disc brake swap?????
Check the 10-bolt sticky for the info you require (the braking systems between the 9- and 10-bolt are identical).
JamesC
Old Feb 1, 2012 | 12:42 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Not REQUIRED. Some say they noticed a difference in not swapping it, some didn't. I didn't years ago.
I say put it in first, then decide if you want to swap the valve or not.
Old Feb 1, 2012 | 03:29 PM
JamesC's Avatar
There's no single combination valve that fits all applications (if there were, no discussion would be required); instead there's a combination valve for each of the three braking applications: disc/drum, disc/standard disc, and disc/1LE--each increasing in rear bias. Different part numbers for each valve and so on. Best bet for best braking performance is the correct valve for your application. Or an adjustable.
JamesC
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Jan 19, 2016 12:21 PM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
