85 trans am rear brakes not working
Old Feb 19, 2012 | 02:32 PM
Dskeezy16's Avatar
Car: 1985 Firebird Trans Am
Engine: ls1
Transmission: t56
Axle/Gears: 8.8 Ford 3:73's
So the other day i did an oil and tranny fluid change and i decided to run through the gears while the car was up on the stands. when i started braking only my front wheels stopped, the back ones kept on going. I have no idea whats wrong. I have semi squishy brake pedal( squishy till about half way down) and i just bought a brand new master cylinder. I also recently lowered the rear end to get my gas tank out could that have done something to the brake lines? I have no idea whats going on someone please help.
Old Feb 19, 2012 | 02:39 PM
85IROCzzz's Avatar
Car: 91 Z28
Re: 85 trans am rear brakes not working
If it's drums in the rear they might just need to be adjusted. Google how to adjust drum brakes, it's very easy. Half-way squishy brake pedal is an indicator of a rear brake issue.
Old Feb 19, 2012 | 02:50 PM
Dskeezy16's Avatar
Engine: ls1
Transmission: t56
I have discs in the rear
Old Feb 19, 2012 | 03:02 PM
85IROCzzz's Avatar
Car: 91 Z28
Well I don't know much about rear discs sorry maybe someone else can chime in.
Old Feb 19, 2012 | 03:23 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Typical issue with 82-88 iron Delco-Moraine calipers. Check the recall and its 'fix' kit:
http://members.shaw.ca/crussel/recalls/86c28/86c28.html
Did you bench bleed the master?
JamesC
Old Feb 19, 2012 | 06:25 PM
Dskeezy16's Avatar
Engine: ls1
Transmission: t56
No i didnt bench bleed it. It might be helpful to know that when i bled the brakes there was a tiny bit of fluid coming out with no presure at all.
Old Feb 19, 2012 | 08:38 PM
JamesC's Avatar
You'll need to bench bleed to remove the air.
JamesC
1992 Trans Am
May 10, 2023 07:19 PM
Reddeath210
Oct 6, 2015 08:20 AM
AkDrifted
Aug 17, 2015 07:45 PM
kyleb24
Aug 15, 2015 08:24 AM
3rdgenparts
Aug 6, 2015 09:03 AM
