C5 carriers seem unobtanable
Old Apr 14, 2012 | 02:55 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Anyone know of a consistent, affordable supply of these caliper cradles? Even the GM part numbers, if they're not discontinued ( yet )
Old Apr 16, 2012 | 12:15 PM
cavazos31's Avatar
Car: 1988 camaro sports coupe
Engine: Fast Burn 385
Axle/Gears: 9 bolt w/ 3.27 gears
Re: C5 carriers seem unobtanable
Are you talking about caliper brackets? Think they're also called abutment brackets. (?)
front # 12455799, but can't find the rear brackets. Still managed to run across a few sets on ebay. A call to a GM parts dealer should get you a part#.
Old Apr 18, 2012 | 01:27 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
I've also seen them listed as "caliper cradles". Thanks for the part number, I searched google for 90 minutes before posting here.
Old Apr 19, 2012 | 12:52 AM
twigger's Avatar
Car: '91-Z28/'03 Honda 919
Axle/Gears: '99 Zexel 3.42
I could be wrong but I believe they were superseded by the c6 brackets.
Old Apr 19, 2012 | 08:09 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Fully interchangeable?
Old Apr 19, 2012 | 11:37 AM
cavazos31's Avatar
I believe twigger is correct, fully interchangable. Not sure if the casting is the same, (though I'd imagine it is), but I'd look at the C6 brackets. Maybe it's just the brackets I have, but the ones I got with my C5 brakes (used) looked pretty rough. Had to grind a few spots level before I painted them. The ends on the face of the bracket, looked particularly bad.
Old Apr 19, 2012 | 11:41 AM
twigger's Avatar
I do believe so, I was at the dealer asking about them and they said they were replaced with the C6 which should be identical. You could try Tobin at Kore3 brakes he could tell you for certain.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
gord327
Oct 3, 2015 01:25 PM
georgiaslim45
Sep 9, 2015 08:12 PM
georgiaslim45
Sep 9, 2015 08:11 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
