Brake upgrade questions
Car: 1988 IROC-Z Camaro, 1981 Trans Am
Engine: 350 TPI, 301 N/A
Transmission: 700r4, 350thm
My car is 4 wheel disk (j65). I have drilled & slotted rotors for the front (havent installed yet) but other than that its a completely stock brake system. My brakes are like most 3rd gen's it sounds like, they leave alot to be desired.
I know the chances of coming across an 1LE car in a junkyard is slim, but other than that, what options do I have?
IIRC, in 89(?) they switched from 10.5in rear to 12in rear rotors, correct? If so, will they fit onto my 88 rear end? Any fabrication needed?
Could I put the rear 12in rotors on the front?
Are 4th gen rotors 12in? Can they be used?
Ive read where people put 'vette calipers on fbodies but its a bit confusing, how much fabrication is need to do this?
Are there any more tips/suggestions on this? My budget is fairly low, i cant spend a whole lot on this unfortunatly. Thanks for the help
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Brake upgrade questions
The first link in the above thread provides a front brake 1LE write-up. The thread itself details the rears. There are many options, however. Peruse the site below:
http://www.flynbye.com/catalog/c1_p1.html
JamesC
Car: 90RS Conv.
Engine: 383 w/ small shot
Transmission: th400
Axle/Gears: moser 9in
wilwood has a gm metric caliper replacement. its lighter than stock and has a 2.75 bore. I just bought mine but havent had time to test them out yet,
Transmission: World Class T-5
Axle/Gears: BW 3.45
Car: 90RS Conv.
Transmission: th400
http://www.speedwaymotors.com/Wilwoo...ton,24192.html
heres a quick link. should be able to get out this weekend.
Axle/Gears: BW 3.45
