1LE Rotor
Old Sep 9, 2012 | 10:15 AM
Vertigo107's Avatar
Car: 86 ASC Convertible #90
1LE Rotor
86 Z28. Quick question; when doing the 1le swap, do I have to have the 2 piece hub/rotor separate, or will the 1 piece hub/rotor suffice when it says its for the 1le fronts.
Thanks.
Old Sep 9, 2012 | 10:28 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 1LE Rotor
1LE uses a 1 piece hub/rotor.
Old Sep 9, 2012 | 10:53 AM
Vertigo107's Avatar
Re: 1LE Rotor
Thanks!
Old Oct 22, 2012 | 09:14 PM
recarosp's Avatar
Car: 83 Recaro TA/ 95 TA
Engine: 355 / LT4
Transmission: turbo 350 / 6 speed
Axle/Gears: 373 / not sure think same
Re: 1LE Rotor
What do I need to swap out to do the 1le conversion in the front just the spindle,rotor and caliper as a unit or do I need to swap out the strut and lower control arm also
Old Oct 23, 2012 | 04:34 AM
Vertigo107's Avatar
Re: 1LE Rotor
Just the modified spindles, 1LE rotors and calipers.
Old Oct 23, 2012 | 05:22 AM
Twin_Turbo's Avatar
Re: 1LE Rotor
and abutments specific to 1LE and adapter brackets. The caliper is a normal J55 caliper, same as on ZR1 corvettes or others optioned with the J55 option. The Grand Sport is similar just a different casting (supposedly a little stiffer) which is the same casting used for the BAER track system calipers brack then.
Old Oct 23, 2012 | 08:40 AM
Vertigo107's Avatar
Re: 1LE Rotor
Yep, what he said :-)
Fanatic1074
Oct 3, 2022 05:57 AM
loud91rs
Oct 5, 2015 10:05 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
the_hamturdler
Sep 30, 2015 12:50 PM
the_hamturdler
Sep 22, 2015 02:59 AM
