Firebird brake pad swap - now have leftover spacer
Old Dec 15, 2012 | 11:41 AM
chrismustang's Avatar
Did a front pad swap on 3rd gen firebird. When I slid the caliper off the rotor two small spacers/washer fell out, I think they were between the calliper and the caliper mount, with the caliper bolts going through them. They look like small length of steel tube, half inch long and half inch diameter.
Trouble is now with the new pads bein thicker, these spacers won't fit back in.
What an I doing wrong?
Old Dec 15, 2012 | 11:47 AM
Re: Firebird brake pad swap - now have leftover spacer
Sounds like the bushings that are supposed to be inside the holes in the caliper where the bolts go.
Time for new calipers. They're SO CHEAP, not even worth worrying about. MUCH cheaper than the pads, amazingly enough. About $25 for both sides.
Old Dec 15, 2012 | 11:50 AM
Can I simply push them back into the holes for now then? I'm in UK so takes a while for parts to arrive
Old Dec 15, 2012 | 11:55 AM
Yes you can do that, temporarily; problem is, they're mounted in some rubber rings up inside there, and if they came out, it's because the rubber has disintegrated. So they'll still work, but might be noisy or otherwise not be right.
Old Dec 16, 2012 | 01:06 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
You might be able to pick out the remnants of the little rubber isolator ring, and improvise a new one with a piece of rubber hose of the right size, with a little work. I recall doing something similar on one or my rears, could not source a caliper pin kit over here or online at the time.
If the rubber rings are in fact ok, the metal spacer thingies will be a pretty tight fit inside. Lube them with a little bit of light oil, and use locking pliers etc to press them back in. They will need to be positioned fully back inside the caliper ears; iirc looks like they work their way outwards as the pads wear.
Vintageracer
Jan 10, 2020 05:33 PM
Eric-86sc
Apr 3, 2016 03:52 PM
articwhiteZ
Aftermarket Vendor Review
Aug 18, 2015 07:26 AM
kyleb24
Aug 15, 2015 08:24 AM
Zachattack0925
Aug 12, 2015 09:52 PM
