Link to caliper and brake pad fix?
Old Jan 17, 2013 | 09:21 PM
AggieIROC13's Avatar
Hey guys, I just got my brakes inspected because they were starting to squeal. Turns out I was told I need new brake pads and i think calipers (or was it rotors?) Idk, I have the paper but it is in my car. Either way, could this job be done by an average joe or do I HAVE to spend the $800+ the shop wants to get them fixed?
Old Jan 18, 2013 | 07:11 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Link to caliper and brake pad fix?
Probably pads and rotors, but even if the calipers need replacing, the whole business is cheap--try pricing them at one of the on-line parts stores for an idea. This is a job that you can do with a few basic hand tools. The amount the shop is asking is out of line.
JamesC
Old Jan 18, 2013 | 07:21 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I agree. Normally squealing is the indicators on the brake pads, meaning the pad is starting to get thin. Brakes are cheap for our cars even calipers are around $20 for reman. ones for the normal single piston fronts. This last brake change I just put reman'd calipers on too since the OEM ones had 100k+ miles and I wanted to paint them.
Remember to get inner and outter wheel bearings and a inner seal when changing the fronts.
$800 is far too much for a brake job IMO. My sister got quoted at $400+ to have disc brakes done on her G6. I was able to do the entire job in 2-3 hours and spend 1/2 that including the gas tank fill up on the car used for parts run.
Remember shops normally charge anywhere from $30-$70 per hour. That's where the majority of the price comes from.
When I price things I use AutoZone, Oreily Auto Parts, or Advanced Auto Parts websites. I can get prices depending on store locations I select then I know where to go to get the parts the cheapest.
There is a sticky at the top of the forum that describes how to replace the front rotors.
Vintageracer
Jan 10, 2020 05:33 PM
Eric-86sc
Apr 3, 2016 03:52 PM
g.l.mos
Aug 22, 2015 12:02 AM
articwhiteZ
Aftermarket Vendor Review
Aug 18, 2015 07:26 AM
kyleb24
Aug 15, 2015 08:24 AM
