Buying new hardlines... is this right?
Old Jan 23, 2013 | 06:22 PM
blakecharles's Avatar
I have LS1 front and rear brakes. I would like to buy hew fuel hardlines (they will not all be used). I just wanted to make sure I'm looking at the right kit
Should I buy CCB8203
http://inlinetube.com/Preformed%20Li.../CC-CAT-08.htm
CCB8201 1982-83 Power Disc Brake Line Set 7pc Standard Fittings
CCB8202 1982-83 4 Wheel Disc Brake Line Set 7pc Standard Fittings
CCB8203 1984-92 Power Disc Brake Line Set 7pc Metric Fittings
CCB8204 1984-92 4 Wheel Disc Brake Line Set 7pc Metric Fittings
Old Jan 24, 2013 | 05:32 AM
Re: Buying new hardlines... is this right?
Those would appear to be the ones for drum rears. (since they are distinct from those for 4-wheel disc)
Should be fine if the 2 you don't plan on using are the ones that go on the rear axle, and it's important to you to have something left over to put in the trash at teh end of the project.
Not sure why that would be A Good Idea though, considering that for the same price, you can get a set w all 7 that you can actually use, in case you just decide to, or need to someday.
You'd more likely want the 8204.
Old Jan 24, 2013 | 11:48 AM
I don't know why I didn't see that! thanx
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Reid Fleming
Oct 10, 2015 09:56 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
