line-lock questions
Old Apr 1, 2013 | 02:42 PM
killerkev's Avatar
Car: 92 formula
Engine: 350 tpi
Transmission: damn 700r4
line-lock questions
i have a 92 formula 350 (TPI) and am wanting to install a line lock.all the kits i see say not for abs brakes and the fitting kits are not for metric fittings... are my fittings metric??? and will this work on my car any help will be great!!!the killer
Old Apr 2, 2013 | 11:57 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: line-lock questions
Yes your car is metric and no you don't have abs. Most parts like that use sae fittings, but after that, you can use anything you want. You have to make up some tubes to install the part, just use the proper fittings on each side.
Old Apr 2, 2013 | 01:03 PM
572_Rat's Avatar
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
You can thry SLP line loc, they make them for our cars with lines pre bent and all the fittings
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
