Need help... Drum brake rearend in disc brake car.
Old Apr 8, 2013 | 10:17 AM
VandykeT/A's Avatar
When I bought my 89 Iroc the brakes weren't exactly the best. I replaced the calipers and hoses (fronts were sticking) I started noticing the front brakes would grab alot more than the rears. So I started looking around at my rpo codes and the car originally had rear discs on a 2.77 geared 9 bolt. Now the car has a drum brake 10 bolt in it. I'm assuming thats the reason I don't have up to par rear brakes. I've been searching but I can't find where someone went disc to drum it was always the opposite. What exactly will I need to change to get the rear brakes working normally? Change the prop valve. I have a 82 car I could take parts from but since my car is a 89 and the donor is a 82 wouldn't the 82 have standard and the 89 metric?
Old Apr 8, 2013 | 08:50 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Need help... Drum brake rearend in disc brake car.
Yes. And there are two different tube nut sizes for the combination valve in 89.
JamesC
Old Apr 8, 2013 | 09:37 PM
VandykeT/A's Avatar
Well could I just cut and reflare the metric line of the 89 using the nuts and proportioning valve of the 82? I used standard nuts on metric line when I did the abs delete on my 4th gen. Would I be able to do the same for this?
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
overdriv
Aug 20, 2015 03:52 PM
