I have a 1990 vert rs, and looking to change the rear drum brakes to disk, I was wondering if anyone knew the best way to do this, or how to go about doing it.
http://www.flynbye.com/index.html .or swap in a 90- 02 rearend.
Ok thanks for the info, but another question which way do you think would be the better of the two.
JamesC
close
Many questions, perhaps some you haven't considered, will be answered in the following link:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
JamesC
im was similar situation, 91 RS drum rear, and I swapped to the LS1 rear discs (left the same rear end). There is a tech article on how to do it
https://www.thirdgen.org/ls1reardisc
Happy swapping which ever way you go!
Thanks for the help and the great info.
