Brake Light
Old Apr 21, 2013 | 10:18 AM
Shep5B's Avatar
Car: 1985 IROC-Z H.O. 4bbl
Engine: L69 Small-Block, 305
Transmission: Borg-Warner T5
Brake Light
Wats happenin fellas..I'm having a problem. With the brake light not turning off.. Ive bled the brakes like crazy/// ive applied mad pressure to the brakes it still wont turn off..(most likely. I dont believe its the e brake. Because when i took the electrical connector thats on the master cylinder off. The brake light turned off.... Plus the brake fluid is above the minimum. So am still confused at whats the problem. Mean while the brakes. Stop fine..
Ps.. One thing i have noticed is that. The caliper i changed in the back left. When i bleed that.. At some point i literally get no fluid coming out.
But thanks yall. Just let me know if you guys got any answers to this
Old Apr 21, 2013 | 11:29 AM
Ransford2987's Avatar
Car: 1990 IROC-Z/1980 Firebird
Engine: 5.7 TPI
Re: Brake Light
Maybe this will help?
Attached Thumbnails Brake Light-20130421_120636.jpg   Brake Light-20130421_120744.jpg   Brake Light-20130421_120759.jpg
Old Apr 21, 2013 | 11:30 AM
Engine: 5.7 TPI
Re: Brake Light
And this...
As far as that caliper you're having trouble bleeding, how long has the fluid been in it unchanged, and how does the fluid look (or how did it look before you bled the brakes)? You could have some debris causing blockage in the line that isn't allowing the pressure to be transmitted to the caliper piston, and thus you don't get any fluid out when bleeding it. I don't have much experience with the brake warning lights on these F-body cars, but I think the issue is related to the D/P switch on the proportioning valve, which is where I would start. Change that out and see if you still have the same problem. Your system could need to be flushed, so I would do that too while I'm at it. Good luck and let me know what you find.
Attached Thumbnails Brake Light-20130421_122057.jpg   Brake Light-20130421_120812.jpg
Old Apr 22, 2013 | 06:02 AM
Shep5B's Avatar
Re: Brake Light
Hey thanks for the advice.. Im thinking. I may have to bleed the entire systems and probbly change the hoses.. Its been a while since its been completly drained..And like u said theres probly all sorts of debris thats in the lines. Thats causing the problem
Old Apr 22, 2013 | 11:41 AM
Engine: 5.7 TPI
Re: Brake Light
Hopefully that's all it is. It's probably cheaper to just buy some brake fluid and flush the system than to buy some parts that may not fix the issue, though it will take some time and usually 2 people.
Old Apr 27, 2013 | 06:02 PM
Shep5B's Avatar
Re: Brake Light
Hey man. I just wanted to let you know, i got the light to shut off..i flushed the entire system with new fluid(gravitybled). Then i pressure bled it. And the sht came out pure with the new brake fluid.. Thanks wid the help
Old Apr 27, 2013 | 06:20 PM
Engine: 5.7 TPI
Re: Brake Light
That's great news! At least you didn't have to buy a bunch of stuff that didn't work. I'm glad to help.
Old Apr 27, 2013 | 07:21 PM
greggbruce's Avatar
Car: 84 454 monte, 89 formula, 86 camaro
Engine: the bigger the better
Transmission: 700/4L60 in everything
Axle/Gears: wish they were all 4.10's or better
Re: Brake Light
that means the switch in the master cylinder for the float is bad. Leave it off, or replace the master cylinder/reservoir.
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
