91 RS conversion to rear discs on a 9 bolt swap....question?
Old Aug 7, 2013 | 01:37 PM
bonylad's Avatar
Car: 09 Honda Fit / 91 Camaro RS
I scored a 9 bolt 3.27 posi diff with all the goodies (calipers-brackets-pads-lines-parking brake) for 75.00. I am taking it and putting it in place of my stock RS 2.73 one wheel wonder.
My question is, and I am am getting conflicting info on the parking brake cables....will the ones in the RS bolt up to the 9 bolt? I believe I may have to get a prop valve for the discs to work at their best, and the parking brake cables IF they fit will require some tweaking to work properly.
Any input?
Thank you!
Old Aug 7, 2013 | 03:24 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: 91 RS conversion to rear discs on a 9 bolt swap....question?
Which disks? Delco or PBR? If you currently have drums the cables are different. The Delco brakes have different length cables the PBR are the same length. You may need the intermediate park brake cable too.
Old Aug 7, 2013 | 03:35 PM
bonylad's Avatar
Sorry. PBR calipers. Thanks!
Old Aug 19, 2013 | 11:10 AM
slowsi's Avatar
Car: 89 Iroc
Engine: 5.0L
i just changed mine yesterday...you have to adjust the parking brake cable above the driveshaft...and i changed the proportioning valve. easy job to do
Old Aug 19, 2013 | 02:52 PM
bonylad's Avatar
I intended to switch it out and adjust the cable before I put the driveshaft in. What prop valve did you use? Thank you!
Old Aug 20, 2013 | 04:37 AM
slowsi's Avatar
Car: 89 Iroc
Engine: 5.0L
I used the same one that was in the car as the rear end. I am finishing everything up on friday. I will keep you posted on anything special I do.
Old Aug 20, 2013 | 07:22 AM
bonylad's Avatar
Thank you :P
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
sailtexas186548
Jan 19, 2016 12:21 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
