89-92 1LE Caliper & flex hose ?
Old Sep 11, 2013 | 03:31 PM
Scott89TTA's Avatar
Car: 1989 Turbo Trans Am 20th/Pace Car
Engine: 3.8 V6 Turbo
Transmission: 2004R Billet, Brake, 3600 Stall
Axle/Gears: 3.70 NITRO Gears
Did all 89-92 f-bodys with front and rear disc brakes have the 1LE package? I have a 89 TTA with 1LE brakes that I'm trying to fine S/S braided brake hoses to replace my original rubber hoses. I'm getting hard pulling and an occasional caliper hang and expect the hoses are failing on the inside. Russell makes a 5 piece kit P/N 692370 that says it is for 89-92 Camaro/Firebird/Trans Am front & rear disc brakes. I talked to both Summit and Russel tech lines and neither could verify anything about the kit being for the 1LE brakes or not? Next question is if two 4-wheel disc brake options were available do they use the same flexible brake hoses? Here is the Russel kit at Summit http://www.summitracing.com/parts/ru...0/applications
-Scott
Old Sep 11, 2013 | 03:54 PM
GTAman's Avatar
Car: 1988 Trans am GTA
Engine: corvette 350 swap
Transmission: t-5 swap
Axle/Gears: 3.27:1 borg warner 9-bolt w/ PBRs
Re: 89-92 1LE Caliper & flex hose ?
1) no. 1LE "Performance package" had big aluminum brakes front and rear. the regular "non-performance package" 4 wheel disk package had iron calipers in front, and aluminum brakes in the rear (because the old delco-moraine calipers were terrible). look for hose sets that specifically say for performance package or 1LE.
Old Sep 12, 2013 | 08:31 AM
Scott89TTA's Avatar
Anyone know who sells S/S braided hoses for 1LE "Performance Pkg." brakes? I'm not finding any...
Old Oct 5, 2013 | 07:53 AM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
Call Earls or Russell Direct and ask them, They used to make them I know.
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
the_hamturdler
Sep 30, 2015 12:50 PM
mfp189
Sep 27, 2015 09:25 AM
