pbr's on a 1988
Old Mar 1, 2014 | 02:09 PM
scoflaw's Avatar
Car: 1988 gta
Engine: 383
Axle/Gears: 9 bolt 3:23
pbr's on a 1988
Are the pbr's a direct bolt on with nothing else to do on a 1988 9 bolt with disk brakes?
Old Mar 1, 2014 | 02:36 PM
Re: pbr's on a 1988
Yup; the backing plates bolt to the same flange on the housing.
Old Mar 1, 2014 | 03:46 PM
scoflaw's Avatar
Car: 1988 gta
Engine: 383
Re: pbr's on a 1988
Can I assume that the direct bolt on is limited to 1992? And the e brake cables are a story in itself?
Old Mar 1, 2014 | 05:37 PM
Re: pbr's on a 1988
Of course not. Why would that year be any different from any other?
Old Mar 1, 2014 | 05:40 PM
Re: pbr's on a 1988
I should mention however, that 10-bolt backing plates won't fit a 9-bolt, or vice-versa. So if your 88 is a 9-bolt, you'll have to come up with the 1-yr-only 89 9-bolt PBR backing plates. But they bolt right up, same as the Saggy backing plates that are there now.
Old Mar 1, 2014 | 05:54 PM
scoflaw's Avatar
Car: 1988 gta
Engine: 383
Re: pbr's on a 1988
Thanks, that was the info I was looking for. 89 backing plates only
Old Mar 1, 2014 | 08:53 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: pbr's on a 1988
Backing plates: http://www.flynbye.com/catalog/i31.html
Swap info: https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
sammy52401
Nov 11, 2015 07:20 PM
///DAN///
Sep 25, 2015 02:15 PM
