Is it possible to...
Old Apr 8, 2014 | 07:04 PM
9manastacio's Avatar
Car: 98 camaro ss, 98 grand cherokee 5sp
Engine: 5.7 ls1, 4.0 sixxer
Transmission: T56, ax15 swapped
Axle/Gears: 3.42, 3.73
I was wondering if a 10 bolt axle housing itself is the same between drum and dic for pre 89 apps. I have an 85 trans am with discs, and can get a drum axle locally. Can't I swap axle shafts and backing plates/calipers rotors? Just want to make sure. Any help much appreciated
Old Apr 11, 2014 | 06:33 AM
Re: Is it possible to...
Nope, not the same.
Disc ones have a small, almost symmetrical (emphasis on "almost") flange w 4 bolts.
Drum ones have a flange that's smaller at the bottom, has only 2 bolts (which are in different places than any of the above 4), and a large thing that sticks upward, that the slave cyl goes through and attaches to.
Nowhere near a direct swap. But, if you can drill WITH PRECISION, it is said that it can be done. Never done it myself; I always have just hunted down the right part.
Might want to consider 4th gen rears instead.
Old Apr 11, 2014 | 02:24 PM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Check out www.autoweldchassis.com
Old Apr 12, 2014 | 09:35 AM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Would these instructions for drum to LS1 brake swap work for the 85 discs, too?
Old Apr 12, 2014 | 09:38 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I have converted a few drum rears to disc, it's not hard at all.
Have to cut off the top of the drum rear flange, drill some holes and use disc rear axles or have the drum axle flange turned down a bit so the rotor sits flat on the axle.
Easy.
DuronClocker
Oct 25, 2004 03:06 PM
3rdGenSS
Aug 25, 2004 05:12 PM
Maverick H1L
Aug 10, 2004 12:34 PM
TheGreatJ
Jul 21, 2004 06:13 PM
Demon Z28
Pacific Northwest Region
32
Jun 25, 2001 08:05 PM
