rear brake ?
Old Apr 21, 2014 | 07:04 PM
silverlsx's Avatar
rear brake ?
I upgraded the rear end to to a 98 model camaro rear with disc brakes. It drives fine and it stops but under hard stops it doesnt. Do I just need to a upgrade the proportioning valve or do I need to do something else? Help would be greatly appreciated.
Old Apr 22, 2014 | 08:16 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: rear brake ?
Do you have to swap to a newer style master cylinder and everything for that swap?
That my be worth looking into.
Also make sure the brakes are well bled.
Old Apr 22, 2014 | 09:05 AM
silverlsx's Avatar
Re: rear brake ?
I don't know that's what Im asking. It stops and all that In town. But try stopping fast It doesnt. I know someone on here has done a 4th gen rear swap that should know.
Old Apr 27, 2014 | 10:14 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: rear brake ?
Most likely you didn't change the proportioning valve although it could be simple stuff like bad pads, air in the lines, stuck pistons or guide pins frozen.
Vintageracer
Jan 10, 2020 05:33 PM
Eric-86sc
Apr 3, 2016 03:52 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
kyleb24
Aug 15, 2015 08:24 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
