rear center brake hose
Old Aug 8, 2014 | 07:44 PM
89 formula TPI's Avatar
Engine: LB9 5.0L TPI
Axle/Gears: 9-bolt Borg Warner, 3.45
hi guys,
have an 89 formula w/ rear discs. where is the rear center brake hose and is it difficult to change?
Old Aug 8, 2014 | 09:06 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: rear center brake hose
Originally Posted by 89 formula TPI
hi guys,
Its almost center (left center) of the rearend to the left frame rail.
Stick your head under the car and look, you'll see it.
Old Aug 9, 2014 | 01:27 AM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
what he said. when you look you will find it. for a reference it is number 5 in the pic here....
http://parts.nalleygmc.com/showAssem...rimLevel=15260
Old Aug 10, 2014 | 07:08 PM
found it, tks guys. doesn't look too bad.
what's giving me issues now is disconnecting the parking brake cable. how do i relieve the tension so i can unhook the cable? i loosened the center nut but the cable runs through a plastic sleeve/coating that seems to be maintaining the tension, here is a pic of the assembly.
any creative ideas/tips welcome
tks all
Old Aug 10, 2014 | 07:21 PM
TTOP350's Avatar
Move the lever towards the cable housing mount. (that cable housing looks bad on the other side of the bracket)
Its best if you unhook the cables from the center of the car 1st, that makes the job easy.
Old Aug 11, 2014 | 05:49 AM
So that would be rotating that lever counter clockwise? Any suggestions how to best do that? Hard to grip anything and overcoming that spring is difficult
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
