Quick flare question (1/4" with 6mm tool)
Old Sep 10, 2014 | 04:57 PM
WTR388's Avatar
Car: 87 Trans Am
Need to replace rear brake line (pinched during my ls swap)
Can't find 6mm tube anywhere around here unless I buy an entire $50 roll. So I plan to use some 1/4" and drill out the nuts.
Will my 6mm bubble flare tool work on the 1/4"?
Old Sep 10, 2014 | 07:13 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Re: Quick flare question (1/4" with 6mm tool)
How long is the piece you are replacing, need to be?...I'm assuming you're talking about the line that sorta conforms over the rearend?
Brake lines are doubled inverted flared.
You sure you asked the right question at the AP store?
i/e
"I need a 32 inch 6mm brake line"
"sorry sir, we have one in 30 inch long, or 34 inch long"
Take the 34 and put a service bend in to shorten it....it will have the proper flares and nuts on it already.
Not trying to talk down to you, as you may already know what I have mentioned, just trying to cover your bases.
Old Sep 10, 2014 | 09:47 PM
WTR388's Avatar
Car: 87 Trans Am
It's the line from prop valve to the rear.
It's 6mm with a bubble flare.
They have no sizes at all for 6mm, unless I buy an entire $60 + 13% tax roll.
The 1/4" is marginally larger.
Old Sep 11, 2014 | 12:38 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
You can still buy two lengths, and use a coupling between them.
Edit:
Sorry...I didn't read the part of your post that said they don't have any 6mm lengths at all.
Uh...where do you live...lol
Old Sep 11, 2014 | 02:45 AM
WTR388's Avatar
Car: 87 Trans Am
I live in petawawa Ontario. It's a military base about 2 hours from a town that might carry something I need. The guys at the napa counter here know me by now, I can't imagine what they think my car looks like after all the random parts I've ordered and say its all going in to one car.
Old Sep 11, 2014 | 07:34 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
It will work fine I've done it a million time.
Dkelz313
Apr 7, 2016 10:38 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
