bigbrakeupgrade.com
Old Oct 13, 2014 | 08:04 PM
rdsxfn524's Avatar
bigbrakeupgrade.com
i'm wanting to do a brake swap but im a little confused, on the big brake upgrade website am i looking for "ls1 complete conversion," is that a "plug-n-play" set?
Old Oct 13, 2014 | 09:19 PM
wildjyoung's Avatar
Car: 1991 Trans Am GTA, 2003 Grand Am GT
Engine: 350 Tune Port
Re: bigbrakeupgrade.com
Mine was plug and play. The whole setup was installed without an issue.
Old Oct 14, 2014 | 10:57 AM
rdsxfn524's Avatar
from bigbrakeupgrade?
Old Oct 16, 2014 | 02:22 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Looks to be plug & play to me. The only thing I see missing is brake fluid to bleed the system.
There is another item to consider, that is the spindle to strut bolts (2 per side). Sometime along the way GM switched to torque-to-yield (TTY) bolts. Or maybe they were always TTY, I don't know. I do know that in '92 the bolts are TTY and need to be replaced each time they are loosened.
Been there, didn't do that, have some bolts that are in two pieces...
RBob.
Old Oct 17, 2014 | 01:29 AM
peterc005's Avatar
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
It's as plug and play as you can get.
Support the A Arm with a jack.
Disconnect brake line
Remove the tie rod end from spindle
Disconnect the ball joint
Remove two bolts to strut
Reverse to install complete brake and spindle assembly
I got the LS1 brake upgrade from Scott and was very impressed.
Old Oct 17, 2014 | 04:54 PM
TallTim's Avatar
Car: 1989 Formula T-Top
Engine: 350 TPI, twin turbo
The turn stop or whatever you call it may be an issue. Scott does a great job, recommended.
