Servicing rear disc brakes
Old Feb 7, 2015 | 01:36 AM
ta305tpi's Avatar
Car: 1987 Trans Am
Engine: 305TPI
Axle/Gears: 2:77/WS6
Hi guys,
I'm replacing the 2:77 rear in my '87 T/A with a 3:27 rear from a '88 GTA. I'll be replacing the brake pads also...my question is...does the piston go strait back into the caliper or do I have to turn the piston as it goes back in?...I've never done rear brake pads before...did a search on this topic with no help...Thanks!
Old Feb 7, 2015 | 06:07 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Servicing rear disc brakes
The caliper pushes back in, the only screw out rear calipers I have ever experienced were on German cars.
Old Feb 7, 2015 | 08:37 AM
The piston in that system does both.
Using the parking brake adjusts those by unscrewing the 2 parts of the piston, which if you don't screw it back together, the new pads probably won't fit. There's a "special" tool for this, not sure how practical it is to do it without it.
Then, the entire piston just presses back into the caliper body.
Make sure you use the parking brake EVERY TIME you park the car, and maybe twice on Sundays just for good measure, to keep em adjusted up as the pads wear.
Old Feb 7, 2015 | 09:11 AM
Engine: Lb9
Transmission: M20
Must be the crappy cast iron calipers.
Old Feb 7, 2015 | 03:03 PM
Car: 1987 Trans Am
Old Feb 7, 2015 | 03:47 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
PBR's were intro ducted in 89.
JamesC
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
novaderrik
Aug 10, 2015 12:44 PM
