so im looking for rotors and pads.
Old Jun 20, 2015 | 08:35 AM
edwardk12687's Avatar
Car: 89 iroc
Transmission: t5
Axle/Gears: 323
so I'm looking to upgrade my brakes a little bit now a HUGE difference resulting in 1000's of dollars worth of parts lol. i just need the car back on the road. so i was looking into a decent set of ceramic pads and maybe a ds rotor. but i cant find anything anywhere. be sides summit which there rotors are made in china then drilled over here i assume. after researching i was thinking of going with brake motive. but i cant find anything that will fit my gta. because of some performance package ?
Old Jun 20, 2015 | 01:56 PM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Re: so im looking for rotors and pads.
if you have the optional 12" brakes with multipiston calipers on the front- essentially Corvette brakes- then the only way to "upgrade" would be to swap to the later LS1 brakes, which have a thicker rotor and bigger pad... drilled and slotted rotors are just a marketing gimmick to get you to spend more money without any benefit on anything that isn't a dedicated ***** to the wall race car- and even a lot of those guys just use cheap parts store rotors because they are a throw away item.. just get the best ceramic pads and cheap rotors and look for other places to spend your money that will actually improve the performance of the car.
Old Jun 21, 2015 | 07:56 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
89-92: front performance package included dual piston alum calipers and larger rotors. In those years if you had a J65 car (four-wheel discs), the rear was equipped with single-piston alum calipers and larger rotors. For marketing purposes, I guess, these were often called 1LE or performance packages. 82-88 J65 cars have the Delco-Moraine iron calipers all around. No 1LE, no performance package.
JamesC
Old Jun 21, 2015 | 09:01 AM
Car: 89 iroc
Transmission: t5
Axle/Gears: 323
[QUOTE=JamesC;5931227]89-92: front performance package included dual piston alum calipers and larger rotors. In those years if you had a J65 car (four-wheel discs), the rear was equipped with single-piston alum calipers and larger rotors. For marketing purposes, I guess, these were often called 1LE or performance packages. 82-88 J65 cars have the Delco-Moraine iron calipers all around. No 1LE, no performance package.
ahh ok then i guess i dont have to worry about then
Old Jun 27, 2015 | 10:35 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Just finished my LS1 drilled and slotted rotor upgrade heres a pic of how it looks
Here is the rear drilled and slotted 89+ pbr brakes
Fanatic1074
Oct 3, 2022 05:57 AM
loud91rs
Oct 5, 2015 10:05 PM
the_hamturdler
Sep 30, 2015 12:50 PM
dbrochard
Sep 25, 2015 04:56 PM
the_hamturdler
Sep 22, 2015 02:59 AM
