Prop/Combination Valve Replacement
Old Aug 31, 2015 | 10:29 AM
RED85TPI's Avatar
Car: 1985 Trans Am
Axle/Gears: 9 bolt Borg Warner Posi 3.27
Hey Guys,
My Prop/Combo valve is leaking brake fluid...(which is wrecking my engine bay paint) Its leaking from where the actual prop valve fits into the into the assembly.
First, can I just take the prop valve out and replace the o-rings without needing to bleed the brake lines?
Second, I was thinking of just replacing the entire Assembly but you can't buy them from a parts store. Is there one that I can simply swap without having to re-flare the brake lines?.. I'd like to just switch it out as simply as possible...
Thanks!
gta90
Sep 15, 2015 04:00 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
