Adapters to convert bubble to double flare?
Old Nov 22, 2015 | 12:19 PM
reborn92rs's Avatar
Car: 92 RS
Transmission: auto
Hey TGO,
I didn't do homework well enough before spending $$$ again. I bought a complete stainless line kit from inline tube (it looks/fits great btw) and had some custom braided hoses made up from BBU a while back to make sure I could run the new LS1 brakes I have. I also have the master and booster from the LS1 to swap over to as well.
The prop valve I have is double flared, I upgraded to disk brakes ages ago and swapped the stock valve out for this one. I flared all the lines to work with it back in the day.
Now the part where I didn't pay enough attention. Turns out flaring stainless is about as painful as it gets. I don't want to mar up my nice new lines. So does anyone have any leads on where to find brass adapters to convert between the two? They must exist!
Old Nov 22, 2015 | 12:22 PM
Twin_Turbo's Avatar
Re: Adapters to convert bubble to double flare?
not sure but looks like it
http://www.autozone.com/brake-system...er/454233_0_0/
Old Nov 22, 2015 | 01:12 PM
reborn92rs's Avatar
Car: 92 RS
Transmission: auto
Thanks Twin, I've been all over that site looking for the right ones, that's SAE to SAE with both ends still bubble from what it looks like. I've stared at so many of these.
Do you or anyone know what size the standard metric lines are? Is it 10mmx1.0 male Bubble flaring?
Old Nov 23, 2015 | 01:02 AM
Twin_Turbo's Avatar
http://www.plews-edelmann.com/hydrau...fittings/?pg=2
last one.
262010 Adapter - Metric Bubble to Standard 10-1.0mm 3/16" (3/8-24)
262011 Adapter - Metric Bubble to Standard 11-1.5mm 3/16" (3/8-24)
262012 Adapter - Metric Bubble to Standard 12-1.0mm 3/16" (3/8-24)
262013 Adapter - Metric Bubble to Standard 12-1.5mm 3/16" (3/8-24)
262014 Adapter - Metric Bubble to Standard 13-1.5mm 3/16" (3/8-24)
262015 Adapter - Metric Bubble to Standard 14-1.5mm 3/16" (3/8-24)
262016 Adapter - Metric Bubble to Standard 10-1.0mm 1/4" (7/16-24)
262017 Adapter - Metric Bubble to Standard 11-1.5mm 1/4" (7/16-24)
262018 Adapter - Metric Bubble to Standard 12-1.0mm 1/4" (7/16-24)
262019 Adapter - Metric Bubble to Standard 12-1.5mm 1/4" (7/16-24)
262020 Adapter - Metric Bubble to Standard 13-1.5mm 1/4" (7/16-24)
262021 Adapter - Metric Bubble to Standard 14-1.5mm 1/4" (7/16-24)
Sooner84
Feb 1, 2016 11:40 PM
84LsxZ28
Oct 12, 2015 05:08 PM
yellowferrari
Oct 12, 2015 11:07 AM
