Factory-Plus Brake Setup?
Old Dec 19, 2015 | 05:41 PM
KMK454's Avatar
Car: 1991 Camaro B4C
My car is going to need some brake work soon (pads, fluid, probably resurface rotors) and I was wondering if anybody was running a factory J65 disc brake setup but with improvements - in other words, it looks stock, but performs better.
If we dissect performance into acceleration, handling, and braking, the stock thirdgen does the best in the first two and the worst in braking. The brakes get the job done, but they lack in pedal feel, initial bite, and the performance isn't as good as you'd expect for such a light car.
So what brake mods can improve braking without going to an obvious aftermarket solution? Or, are the J65 (non-1LE) 4 wheel discs simply limited and maxed out in their original form?
Edit - my car is a lowish mile survivor B4C that I use mostly for spirited weekend driving on fun roads. No racetrack brakes needed.
Old Dec 20, 2015 | 11:45 AM
Re: Factory-Plus Brake Setup?
Probably the best all-around way to go would be the LS1 brakes. You already have the modified spindles, which makes it that much cheeeeeeeper and eeeeeezier.
Old Dec 21, 2015 | 02:05 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
You could refresh everything and put on a set of "sticky" pads.
Here's what I did and it helped a lot compared to the "old" stock pieces .It's single caliper but the general idea = https://www.thirdgen.org/forums/brak...brake-job.html
I like Ceramic pads but there not as sticky as lets say a set of these = http://www.hawkperformance.com/perfo...ormance-street
Old Jan 2, 2016 | 10:43 PM
86firebird350's Avatar
Car: 91 GTA
Axle/Gears: stock
Here's are links to my review as well as Reid Fleming's review of Dean's "ultimate stock set up".
Mine: https://www.thirdgen.org/forums/brak...setup-aka.html
Reid's: https://www.thirdgen.org/forums/brak...-ultimate.html
Old Apr 27, 2016 | 03:06 PM
KMK454's Avatar
Thanks for the link - very interesting info.
I'd also consider an aftermarket setup that does not change factory offset (i.e. - push the front wheels to a wider track).
Showcase1186
Dec 27, 2015 07:10 PM
85@IRocZ
19
Dec 25, 2015 09:33 AM
Slash
Nov 17, 2015 11:54 AM
bamaboy0323
Wheels and Tires
Nov 16, 2015 11:17 AM
85@IRocZ
Nov 5, 2015 11:34 AM
