Brake help please
Old Dec 29, 2015 | 07:50 PM
FiVe KiLLZ's Avatar
From: Home of the world champion San Antonio Spurs. 210 baby!!!
Car: 1992 Z28 Convertible
Engine: LB9 - seeking sped density L98
Transmission: 700r4, have a t5 I am swapping
Axle/Gears: G92 3.23 third gen Borg warner
Brake help please
Have a chance to buy 9 bolt 3.45 rear ended with no brakes.
Can I buy 10 bolt brake set up, and then get the backing plates from flynbye and make it work ornis there more to it than that?
I know I need all the lines and such, but there is a 10 bolt pbr set up off a 90 formula at the JY for 200. don't want to spend the 200 and then they can't swap. Upgrading my daily driver. Any help James C and crew?
Old Dec 29, 2015 | 09:16 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Re: Brake help please
https://www.thirdgen.org/forums/engi...t-pbr-1le.html
help has arrived!
these are for the 89-92 9 bolts axle they use the 89-97 rear calipers with the 89-92 or 93-97 rear 11.6 rotors and calipers, I had a few sets cut off of an original bracket and have been trying to get these out of my garage!
Old Dec 30, 2015 | 06:30 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
With the exception of the backing plates, the 9- and 10-bolt braking system is identical. I'd pick up the combination valve from the donor car as well.
JamesC
Old Dec 30, 2015 | 07:10 AM
FiVe KiLLZ's Avatar
help has arrived!
Thank you much for the response. That clears up confusion with the pics, so thanks for the extra time to forward them also on the post.
Old Dec 30, 2015 | 07:11 AM
FiVe KiLLZ's Avatar
JamesC
Yes sir, your opinion and advice is always on the money. Thank you for your support as always James. Enough can't be said about how cool all you guys are
RScamaro92ZACH
May 15, 2025 09:10 AM
mustangman65_79
Dec 15, 2015 04:18 PM
Foster382
South Central
Dec 14, 2015 08:50 PM
V1nom
Dec 2, 2015 08:03 PM
fordspanker
Dec 2, 2015 11:31 AM
