Wilwood 4pistons kit front / rear - Strange diff 12bolts - Wilwood propo install.
Old Jan 13, 2016 | 01:29 PM
1o80b's Avatar
Brakes ****.
First begin with the front spindles.
They need to be cut like that :
Drill Q hole and tap 3/8
Put the front assembly
Annnnnnnnnnd the caliper
1o80b's Avatar
Re: Wilwood 4pistons kit front / rear - Strange diff 12bolts - Wilwood propo install.
Removed old rear drums and backing plate
Put the new wilwood backing plate in this order.
Now put the rear disk and see that the disk not fit YAY
Test fit how much spacer it need.
Ahhhhh better !
Add longer wheel bolts
Test fit.
Old Jan 14, 2016 | 06:52 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
That is some really nice looking stuff and I`m sure they work great...do they all fit under 15`s? what size rotors etc..?
Old Jan 16, 2016 | 07:27 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I agree , really nice.
Old Jan 19, 2016 | 10:15 AM
1o80b's Avatar
Yep minimum wheel size are 15'' and rotor are 11.5 if I remember correctly.
Outter spacer done.
Front clearance for flexline looks good.
Front spacers installed.
Wilwood front hub seems 1/8 larger than stock
Bleeding is done.
Everything is done.
TKO500
Exterior Parts for Sale
May 7, 2016 08:08 AM
djdsails
Jan 15, 2016 12:46 PM
mike0brien
Jan 12, 2016 10:08 PM
Derrick86
Brakes
Jan 12, 2016 04:53 PM
Kylej68
Jan 12, 2016 01:11 PM
