LS1 rear brake conversion
Old Jan 31, 2016 | 10:58 PM
Whitechevy92's Avatar
Car: 1992 Camaro z28
Transmission: Automatic
Axle/Gears: Stock
Well with income tax coming back I am doing the ls1 brake conversion in the front. I have disc in the back they are pbr. My question is do you have to take out the axle half shafts to do the conversion in the rear. Going to get the rear kit from Ed Miller and the fronts from Scott.
Old Feb 1, 2016 | 06:35 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: LS1 rear brake conversion
Yes.
JamesC
Old Feb 2, 2016 | 06:18 AM
Mario May's Avatar
I might just go with the wildwood if I gotta take the axles out for the ls1 kit. Wildwood said I would not have to take the half shafts out. Thanks for the info
Old Feb 2, 2016 | 06:31 AM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
You need to remove the rear axle shafts (not half shafts) to remove the old backing plate. Therefore, it doesn't matter much if the new kit can be done without removing the axles.
Old Feb 7, 2016 | 11:13 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
you already have decent rear brakes... keep them and spend your money elsewhere.
Old Feb 9, 2016 | 08:02 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Yea, your rears are good if they are the pbr. No point swapping to the ls1 versions.
Old Oct 25, 2016 | 09:56 PM
Axle/Gears: Stock
I have tried calling ed Miller several times I have pbr rear brakes I wanted to run the 13in bear rotor what is the part number for the rear brakes the size is 13x0.81
nova983
Brakes
Oct 25, 2016 09:58 PM
Irockthedrag
Sep 21, 2016 04:55 PM
::Andy::
Apr 17, 2016 06:40 AM
Justin89Formy
Feb 21, 2016 07:20 PM
mike0brien
Jan 12, 2016 10:08 PM
