Another rear brake problem
Old Feb 23, 2016 | 11:02 PM
alpine247's Avatar
Car: 1988 IROC-Z
Axle/Gears: 2.77 posi stock
This past weekend I did the front ls1 brake swap.Stops better then before I must say lol.But can be better if the rears work.Working on a 87 iroc so I have the pos iron calibers.I planned on doing the ls1 rear swap as well.But if I can "bolt on" different calibers without changing the backing plate are change the spring in the valve.Just tell me what should I do.
Old Feb 26, 2016 | 05:45 AM
Re: Another rear brake problem
Changing the prop valve spring is cheeeeeep and eeeeeeezy. Won't substitute for better brakes period, but might at least make them detectable on occasion. I'd say, go for it, while looking for something that actually works.
Old May 24, 2016 | 11:43 PM
G8T8A's Avatar
Car: '88 GTA
Engine: 5.7L
Transmission: 700R-4
For those with rear brakes that won't hold when the rear is supported on jack stands, what is the correct OEM fix if skipping the spring trick? My stock 88 disks and my upgrade to 89 PBRs are just along for the ride.
Is the true root cause a faulty prop valve or master cylinder?
Old May 25, 2016 | 12:15 AM
someone972's Avatar
Car: 1991 Firebird Formula
Engine: 5.7L TPI
I've been trying to get the early 4th gen PBRs that PO swapped on to the car to work better for a long time. Tried the stiffer spring, replace master with a NEW unit, replaced all brake lines, bled everything really well, and it still will barely hold the rear wheels if at all. For me the solution will be to bypass the stock prop-valve and go to an adjustable prop-valve for the rear. I haven't found the time to do that yet, but just wanted to share my experience with the PBR brakes.
Old May 25, 2016 | 08:42 AM
G8T8A's Avatar
Car: '88 GTA
Engine: 5.7L
That sure is frustrating. I want to avoid adding an aftermarket valve if possible. I hope the spring works for me, but I also don't like the idea of just putting a bandaid on it.
uptboi31
Interior Parts Wanted
Feb 1, 2016 07:01 PM
Camaroz2892
Jan 31, 2016 10:11 PM
racereese
Jan 31, 2016 12:00 PM
ev305tpi
Jan 26, 2016 11:54 AM
ostrich
Jan 26, 2016 10:19 AM
