Help with 4th gen rear swap
Old Apr 13, 2016 | 09:30 AM
Base92's Avatar
Car: 1992 Base Firebird
Axle/Gears: 2.73 open diff/welded
Hello TGO, I am new to the forum thing so please excuse me for any errors and for also opening a thread that's probably been beat to death by now.
So..
I own a 1992 Base Firebird that came with an open diff and drum brakes. I had the bright idea of welding it in order to have posi and to enjoy the stuff you can do with full posi... It was fun to have but now I am moving towards building my car and want to start with the rearend. My question is, what will I need to make this happen? I already bought an 02 Z28 Rear that came with ABS and 3.42s. It didn't come with brakes/calipers/brake lines, it's just the rear axle with hub assembly. Can someone help me by giving me a list of what I will need to purchase and what parts they recommend (brake kits, type of proportioning valve, length of brake lines, etc..) I would highly appreciate your help. Thank you
Old Apr 29, 2016 | 06:44 PM
valicswarrior's Avatar
Car: 1985 Firebird S/E
Engine: SBC 350, mild cam Vortec heads
Transmission: Rebuilt 700R4 vette servo+shift kit
Re: Help with 4th gen rear swap
hope you get some help with this, when i swapped mine the rear end I was putting in was complete just weeding out some problems in the brakes. Not sure the entire list you would need to purchase. As for the brake lines I bought the factory rear brake hose with the T block for my car then bought straight brake line and bent it into proper position to the calipers. as for the rest the best idea i can think of would be to go to pick n pull for all the brackets and calipers (buy new pads and rotors on ebay or something)
Old May 1, 2016 | 10:46 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
do you have the disc brake mounting brackets?
Old May 4, 2016 | 07:20 PM
Base92's Avatar
No I just have the bare differential with the reluctor rings and hub assembly. Do I need the brackets first before buying a brake kit?
Old May 4, 2016 | 07:22 PM
Base92's Avatar
[QUOTE=valicswarrior;6033733]hope you get some help with this, when i swapped mine the rear end I was putting in was complete just weeding out some problems in the brakes. Not sure the entire list you would need to purchase. As for the brake lines I bought the factory rear brake hose with the T block for my car then bought straight brake line and bent it into proper position to the calipers. as for the rest the best idea i can think of would be to go to pick n pull for all the brackets and calipers (buy new pads and rotors on ebay or something)[/QUOTE
Could you provide me a link to the t block and brake hose that you purchased
Old Jun 22, 2016 | 11:12 AM
http://www.oreillyauto.com/site/c/de...ord=brake+hose
sorry didn't see this reply brother, if the link doesn't work its part # BH38180 sourced from oriely's auto parts
xbazzarex
Sep 11, 2016 02:38 PM
xbazzarex
Aug 27, 2016 07:18 PM
89irocz355
Exterior Parts for Sale
Apr 4, 2016 12:05 PM
89irocz355
Mar 27, 2016 09:52 AM
I_R_GRUNT
Mar 20, 2016 11:03 AM
