Help with leaking combination/proportioning valve
Old Apr 15, 2016 | 08:16 PM
Recaro T/A's Avatar
Car: 1982 Recaro edition T/A
Engine: Crossfire (305)
Transmission: THM200C
Hi, I have a 1982 Recaro T/A (WS6, 4 wheel disc brakes) and recently discovered a leak coming from the bottom port of the original proportioning valve. I decided to have the local GM dealer replace the valve with an aftermarket one I purchased, but after just a few short drives, I noticed that the aftermarket valve is leaking as well. The aftermarket valve does not have the lower port (as the original one does), but instead, has one on the upper part from which brake fluid is leaking at an even greater rate than before. (See photo of leaking port.) I am not a mechanic, but guessing that these ports serve the same purpose; just in different locations on the valve.
What could be causing both the original and aftermarket valves to leak? Is there some other problem in the brake system that I should consider?
Thanks in advance.
Attached Thumbnails Help with leaking combination/proportioning valve-0415162043.jpg
89irocz355
Mar 28, 2018 08:24 PM
89irocz355
26
Sep 12, 2016 01:28 PM
89irocz355
Exterior Parts for Sale
18
Apr 11, 2016 10:17 PM
89irocz355
Apr 4, 2016 12:05 PM
89irocz355
Mar 27, 2016 09:52 AM
