Wilwood FLS conversion
Car: 1992 Camaro rs, 1988 Iroc
Engine: 305 TBI
Would this Wilwood FSL conversion offer better stopping power than stock?
http://www.flynbye.com/catalog/i104.html
Im looking to upgrade my brakes but I can afford nothing to pricey. I have a 1992 RS disk/drum. Maybe sometime future if budget allows i'll do a disk conversion on the rear.
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
Re: Wilwood FLS conversion
Just an FYI, that is just the spindle and hub kit with the necessary mods already done so the calipers and rotors just bolt on. Add another 550 minimum to this kit for the actual brakes.
Sorry for the bad news.
Your cheapest upgrade is going to be LS1 front brakes. That will probably fit the 550 budget.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
That kit will offer all the stopping power you could ask for - problem is as said, it is not a complete kit. And it won't fit under most of the OEM 16" 3rd gen wheels either...
Car: 1984 z28
Engine: Crate replacement L31R 350
Axle/Gears: 7.625" 28 spline 3.23
Paul, I think the FSL kit with the 13" c4hd rotors fit under the 16" iroc wheels.
I know the Baer Track kit with the PBR calipers and the same 13" rotors won't - neither will it fit under Formula or Cross-Lace wheels. They do fit in 91-92 Z28/RS wheels.
16" tire selection is getting even more scarce these days, plus to get more braking power, you need a wider tire, so 17" and larger is a great way to go - if you can swing the additional cost.
