Big Brake Kit Spindle
Car: 87 IROC
Axle/Gears: LS1 10bolt w/ 3.73
To anyone who has done their own big brake upgrade, LS1 C5, etc, how much grinding did you have to do on the mounting holes? My drivers side spindle seems to be really "high" at the landing points for the caliper bracket. When i did the LS1 swap everything was OK, but i still had to take a file to the top side to bring the mounting points for the caliper bracket into a parallel plane as the rotor.
Now that i have the C5 kit, things seems worse, 1/2" plate, seems really true, but at the bottom the abutment bracket is rubbing badly on the rotor, while the top seems to be offset towards the inside of the wheel well.
My solution is to hit both spots with the 4" grider and then finish with a file. I need to pick up somewhere around .070" By that i mean move the caliper bracket towards the engine bay .070" at the bottom mounting point, and then slightly less at the top.
Any thoughts? Did i just get the weird spindles from the factory?
Re: Big Brake Kit Spindle
I do many,many spindle sets a year give or take and you don`t grind on the dust shield pads except to remove corrosion where the shield did not sit. I do have a few customers and myself that run across a spindle or two a year that the pads are off plane against each other, yes it is unlucky and most likely if you picked up another spindle everything would be perfect.
Most likely if you have ground on the pads, the bracket will never sit true to the rotor again, sounds like it was bad from the get to me.
Car: 87 IROC
I have had this happen, What I did was bolt down the bracket using 1 bolt and then rotate it to see where it hits the other mounting boss. Measure how much it's off and use a pilot end mill and sneak upo to where it's true. Not a problem at all
Car: 87 IROC
I might try something. Otherwise it might be just time to bite the bullet and go hunting in the junk yards.
