Dana 44 brake kit
Car: 91 Formula
Engine: 5.0 tpi slow
Transmission: WC t-5
Dana 44 brake kit
I got a replacement dana 44 going in place of my drum 10 bolt. Does anyone know of a bolt in brake kit for everything? Will everything from a 10 bolt disc fit? Need mounts, backing plates, ect. I'd like to fit in the stock 16 inch wheels
Re: Dana 44 brake kit
Post a photo of the flanges.
Ideally, the 10-bolt PBR system will go on, somehow. It's not hard to find those, specifically on 93-97 Camaro/Firebird V8 cars. For that matter the 98-02 system might even bolt up.
If you're thinking about the crappy 82-88 Saginaw crap disc brakes, you're probably better off driving around with no rear brakes whatsoever... less dead weight that way.
Car: 92 CAMARO RALLY SPORT
Engine: 383 sbc w/250 shot of nitrous
Transmission: AMERICAN POWERTRAIN- EXTREME TKX
Axle/Gears: STRANGE ENG. 12 BOLT 3:90 SPOOL
Been there done that.. Swap out the caliper backing/mounting plates.. That is all that needs to be done in order to bolt up 93-97 calipers and rotors on it. Just sold a complete set up With my old Dana 44 rear, You will need to replace axle bearings and seals to do this. I still have an extra set of the correct retro- fit backing plates. PM me if you are interested in them. Stock wheels will fit great the PBR calipers actually work Like Sofa said the the Saginaw brakes are junk
Engine: 4++,350 & 305 CIs
I put a d44 in place of the factory 10bolt in my 92 formula a couple of yrs ago, I don't remember modifying the backing plates at all.
