C5 brakes on thirdgen ?
Old Apr 22, 2017 | 11:57 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Please point me to the best build thread for this.
Old Apr 23, 2017 | 08:35 AM
Re: C5 brakes on thirdgen ?
They are very close to the same as LS1 brakes. The calipers are a bit better and are red. Other than that, pretty much the same principle.
Check out bigbrakeupgrade.com, I think they have kits for that swap.
Old Apr 24, 2017 | 09:38 AM
tglennon11's Avatar
Car: 87 IROC
Axle/Gears: LS1 10bolt w/ 3.73
http://lukeskaff.com/projects/car/th...brake-upgrade/
walks you through most of what needs to happen for all of the options.
Old Apr 24, 2017 | 11:13 AM
remltr's Avatar
Car: Bone stock 1989 Iroc T-Top,1991 Z28
Engine: 5.7, Carbed 383
Transmission: 700r4, T-56
Big Brake Upgrade for parts. Brakets, bolts, hubs..
Old Apr 25, 2017 | 10:58 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Going through Big Brake Upgrade folks. Just for the front, and the package is around 1k, but now they use C6 calipers because it's basically the same from their perspective.
Old May 5, 2017 | 04:37 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
I also concur on the brake package from bigbrakeupgrade.com. He sent everything that I needed except for the inside bearing and bearing seal for the hub. Those bearings you can scavenge from your existing rotors, and the seal is $5 at the parts store. They are strong enough to flat sport your tires faster than you can say "scrrrrt!"
Corvette brakes from bigbrakeupgrade.com
Old Sep 2, 2017 | 07:44 PM
SixSeriesCSi's Avatar
Car: 89 Formula, 85 Trans AM & 91 Bird
Engine: 5.0 CARB, 5.7L TPI & 3.1L V6
Transmission: T-5/700R4/700R4
Axle/Gears: 9 Bolt & 10 Bolt X2
Hahaha! Very eloquently put
Old Sep 19, 2017 | 05:44 AM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
Not sure if it's an optical illusion or not but that pic looks like the disks are drilled on the bottom half and slotted on the top lol
