Rear disc brake not working
Old May 3, 2017 | 07:10 PM
Sdallaire's Avatar
Car: 1987 Chevrolet CAMARO IROC-Z
Engine: 5.7 crate engine 300hp
Transmission: TH700R4
Hi guys,
need advise here.
i have an 87 iroc with 4 disc brake. The rear disc brake are not working.
I did a master cylinder bench bleeding and a full 4 calipers bleed.
after that, I have the same problem. No rear break.
what could be wrong? Proportioning valve?
thanks
sylvain
Old May 6, 2017 | 04:20 PM
Sdallaire's Avatar
Re: Rear disc brake not working
I fixed it!
i had a bad ebrake cable. Replaced it and pump the lever 30 times. Now they work perfectly!!
Old May 6, 2017 | 05:19 PM
Remember, use the PARKING brake (no such thing as "emergency" brake) EVERY SINGLE TIME you park the car, and twice each time on Sundays just for good measure, to keep the rear brakes working. It's the only way they get adjusted to make up for pad wear.
