re: why would my 89 firebird have 88 rear calipers
Old May 14, 2017 | 01:40 PM
factory89tpi's Avatar
My 1989 firebird has rear brake calipers from the 88 year why is that will the 89 calipers bolt to the same bracket
Old May 14, 2017 | 03:29 PM
Re: why would my 89 firebird have 88 rear calipers
why is that
Probably because somebody changed the rear out at some point in its life.
No
Old Aug 18, 2017 | 07:27 PM
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
Maybe yours was produced early in the run, and they were trying to use up older parts. There's a vin break in 1991 firebirds (built in 1990) where they stopped using an older style electric rear hatch pull down and went to a newer style. The vin on my car says I should have the newer style. Guess what? I have the older style.
Old Aug 18, 2017 | 11:38 PM
Ghettobird52's Avatar
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
^^ this.
My car is an 88 model year but has the older style coolant overflow reservoir that 'stopped' at 87.
cort351w
Oct 26, 2001 07:35 PM
