Drum to Disk Diff Swap
Axle/Gears: 4:10
This weekend I am picking up a disc brake differential for my 85 Z28. After a thorough restoration, what problems am I going to face upon installation i.e....Emergency brake cable change or just adjust???? I have no idea what kind of problems are in-store???
Thank you in advance for your knowledge.
Respectful Regards
Respectful Regards
Car: 86 Sport Coupe
Engine: 5.3 LM7
Axle/Gears: 4th gen 3.42 posi
Re: Drum to Disk Diff Swap
Im not familar with the 3rd gen disk rears, as i went from a drum rear to a 4th gen rear. But you will most likley need to replace your proportioning valve with one from a disk rear, and also get parking brake cables from a disk brake car as well, but Im not 100% on this. Other than that, assuming its fully assembled with calipers, hoses and the hard brake lines, you should be good to go.
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
The drum brake cables will not work,.... the cables you'll need will depend on the disk brakes your using. ( 82-88 disk, or 90-92 disk ?? ) If the rear is a LS1 rear-end ( brakes ) than there are a couple options to get the Parking brake working, but some custom work will be required.
Axle/Gears: 4:10
Thanks John. It's a 1984 Z28 HO. disk brake, posi, and 3:73 gears. Its been setting in dry storage under plastic for the last 10 years......lots of restoration ahead.
The disc brakes before 1989 arent even worth messing with. They wont brake as well as drums. GM issued tech notices and recalls, and finally went to Performance Brake Resources to supply a system that would work.
Just seems like good timing; Send me a PM if your interested in an LS1 rear disc upgrade. ( I took these pics this afternoon while cleaning up in the garage a bit,.... )
P.S. Includes the LS disk E-Brake cables,too - just not pictured. Missing 2 little pins of the E-Brake hardware ( lost them ) and needs new E-Brake lever rubber boots. ( they ALL need new boots. )
Car: 1984 Trans-am
Hey thirgen brothers this weekend after putting a ton of work into my engine i,m upgrading the rear diff as well, My current diff is a stock 1984 drum open diff i don,t know what ratio but it a one wheel peel but in the winter i picked up a sweet 1990 posi diff with the aluminum calipers and the ratio is 3.42 from a 1990 formula firebird my black queen is a 1984 trans-am i seen some where in a post which i can not find about doing this i need to change the prop valve or something about a item from summit i can buy that does something so you don,t have to change the prop valve and if it comes down to having to change the prop valve can i just take a prop valve from a gm car that has disk brakes from a pick and pull or does it have to be from a trans-am/camero thanks for the help hope my post it not confusing
Here is the thread you want to start at: https://www.thirdgen.org/forums/brak...e-upgrade.html
