GM disc/drum prop valves stil available?
Old Jun 20, 2017 | 03:38 PM
Skip Fix's Avatar
Goping to get rid of the poor designed ABS on my 97 Chevy truck- a bad system with variable pedal feel and distance. It has no prop valve I assume built in the ABS so I need one. Ive heard the aftermarkets are variable quality and often SAE thread. Are there any pre ABS metric valves still out there?
Old Jun 21, 2017 | 03:34 AM
NoEmissions84TA's Avatar
Re: GM disc/drum prop valves stil available?
I have a 95 K1500. The ABS failed in a way that all I had to do was pull a couple of fuses to disable it (happy day - I always hated the way it worked). I did not have to mess with any brake lines. Yes, the brakes still are not great, but I will live with it.
Old Jun 21, 2017 | 05:19 AM
shayapaula's Avatar
Car: 84 camaro z28 H.O
Engine: 305 H.O
Transmission: world class T5
Axle/Gears: 3.73 limited slip
Not sure what size lines that truck has but I have a few third gen camaro front disk rear drum prop valves.
