87 IROC emergency brake handle rattles
Old Jul 5, 2017 | 05:00 PM
jeremyb1988's Avatar
On Probation
Car: 1987 IROC-Z Camaro
Transmission: T-5 5 Speed
Hi there, got a question about the parking brake. So my handle rattles like crazy...well actually its the button at the end that makes so much noise. Does anyone know what specific part I need to replace it?
Old Jul 6, 2017 | 09:26 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: 87 IROC emergency brake handle rattles
The button is attached to a long rod that runs the length of the metal arm.Then engages teeth of the sprocket/gear at the other end.Perhaps the rod has slipped out of place.
Old Jul 16, 2017 | 12:25 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
My button will also rattle. It's firmly held in place and works but it can wiggle around thus causing some rattles. I've assumed its all the solid suspension joints and mounts I've changed to over the years adding more vibration to the car. I've heard of guys gluing felt to the inside of the handle by the button. I may try it.
Old Jul 26, 2017 | 11:05 PM
On Probation
When you say gluing felt to the inside of the handle...I have not taken this apart yet...seems like a tight fit...and you would have to use tweezers to navigate the felt inside? Also I assume the felt needs to be on the same side that the button comes out off???
Old Jul 27, 2017 | 12:01 AM
Tibo's Avatar
Car: 1991 Z28 Vert
You're just putting a little bit of felt on the side that the button is on. You could also put it on the button itself. This is basically the same fix as the vents that always flap down. Just a piece of felt.
