pbr rear caliper, where does the H shaped bit go?
Old Oct 28, 2017 | 08:39 AM
warlord's Avatar
Car: 1983 Trans Am t-top
Engine: 305 4bbl carb (vin code H)
Transmission: 4 speed automatic
I've swapped in a 9 bolt from an 89 into my firebird, i'm doing the pads and discs. The hardware kit has a H shaped bit of metal, but i can't figure out where is goes as the old pads didn't have it.
i've added some pics, i could really do with some help.
thank you.
Attached Thumbnails pbr rear caliper, where does the H shaped bit go?-20171028_135035.jpg   pbr rear caliper, where does the H shaped bit go?-20171028_135053.jpg   pbr rear caliper, where does the H shaped bit go?-20171028_135101.jpg   pbr rear caliper, where does the H shaped bit go?-20171028_135124.jpg   pbr rear caliper, where does the H shaped bit go?-20171028_135135.jpg
Old Oct 28, 2017 | 02:06 PM
howie099's Avatar
Car: 1986 Firebird TA
Engine: SBC 350
Transmission: TH350 Stage2
Axle/Gears: 9 Bolt rebuilt w/3.70
Re: pbr rear caliper, where does the H shaped bit go?
You have it correct in your 3rd pic. The pad help push on the top of the clip to hold it in place. I will see if I can see the clip on my setup.
